Looking for location of ABS fuse
Good day, i have a 1992 Series 111 VDP (12 cyl) limited production (84 of 100) vehicle. We have been searching for the ABS fuse for several months
Ten years go my mechanic found it after a lengthy search - now he/ we can not recall where it is. We were not able to get a replacement fuse from Jag dealers in Ottawa , Canada - but friends in the communication field found a replacement - which worked well untill I stupidly put a trickle charge on the battery without disconnecting it, and although it was a 2 amp trickle charge it was enough to pop the fuse. ratings on the replacement fuse are , current 8A; voltage 250 V, Time delay fuse, Size /Group5 x 20 mm. It is a ceramic cartridge type fuse- approx 3/4 inch long. It is not housed with other fuse clusters. Last help we had said it should be behind battery or DVD in trunk. Another suggested it was under the back seat. In spite of looking in and behind & around every conceviable site - we have been unsuccesful in our search. I have a Bosch ABS breaking system. Sure would appreciate help. Ed
ericjansen
12-19-2021 12:20 AM
