Looking for a supplier of Windlace in the America's please - RESOLVED
Looking for a supply of Windlace. This would be the fabric wrapped trim that goes up and down the either side of a 1985 Jaguar Series 3 B pillar?
Thank you.
Larry Louton
Thank you.
Larry Louton
Last edited by GGG; 03-01-2021 at 01:31 PM. Reason: Add "RESOLVED" to thread title
Try these folks Larry, from the samples of upholstery/carpet material they've sent me, they have excellent products.
Dave
Seat Upholstery, Carpet Sets, Converitble Tops, Headliners, Door Panels and Rubber Seals for Jaguar XJ Series Sedans from World Upholstery & Trim
Dave
also check with SNG Barratt USA
https://www.sngbarratt.com/English/#...rnedDown=false
windlace, furflex, draft excluder. Same thing.
If you are wanting to replace these pieces because the black colouring has faded to near-white, you can save your money by simply buying a wide nib permanent black marker; just pull the furflex away from the B pillar metal, colour the bleached canvas surface and it is good for at least another decade. I have done this on multiple restorations - perfect solution.
Mkii250 (02-28-2021)
Reply to LT1. UPH will only sell the entire kit. From A pillar to C pillar. And the B pillar.
Reply to Jose. I am going to call SNG Monday, I'm looking for the "U" shaped fabric covered product. By the pictures they show the foam tube with with the cloth glued around it and or the "U" shape with the rubber tube. How did they come up with so many different names for different parts?
Reply to Sov211. Worn thru to the metal, Well past the fabric. Was considering swapping it from side to side. Then I would only see it when I left instead of getting in.
Thank you.
Larry Louton
Thank you.
Larry Louton
there is a fourth wording for it:
Draught excluder. ( as opposed to draft ).
that is what Jaguar called it in the 1960's Shop Manuals.
Furflex might be a US brand name for it,
Windlace might be the American word for it.
if no luck finding it, then contact John Skinner Ltd. in UK. They have it.
sanchez
01-08-2016 07:24 PM
