Looking for wiring diagram of a 1970 XJ6 series 1
Hi everyone,
I am in the final stage to crank my 1970 XJ6 series 1, however I am facing an ignition issue, I have changed pretty much everything on the ignition line (HT Coil, Ballast resistor, Condensator, points, spark plugs, HT leads) but I am not getting any spark. I have run mutiple tests to check voltage, continuity and so on, and I have noticed weird readings as follow:
Contact Ignition on:
Coil Positive to ground 5.98V
Coil Negative to ground 0.7V
Coil Positive to negative 5.45V
Something's wrong somewhere and that's I am chasing for advice(s) as well as a correct wiring Diagram !
Bertrand
Bertrand
SableXJ6C
03-18-2019 07:19 AM
Daimler
06-14-2013 06:05 PM
