Low Oil Pressure, XJ6
Old 11-10-2014, 06:38 AM
o1xjr's Avatar
Received 6,327 Likes on 4,370 Posts
Originally Posted by Dleit53
Back around 1970 I saw a guy put another engine in his E Type because the oil gauge read low. Once he got the new/used engine in, it read the same. Until he finally replaced the sending unit.
Originally Posted by yarpos
That is an interesting diagnostic approach. All good, as long as he is spending his own money I guess.
I think my 17 bucks was a cheaper way to start the process of elimination.
Old 12-06-2014, 02:16 AM
o1xjr's Avatar
I fitted a second hand sender today($40 rather than $130 for a new one). Same result,low oil pressure.
Removed it again and fitted the mechanical gauge, 40 psi at 2500 rpm,all good. Put the original sender back on since I know how it behaves. I will just test it with the mechanical gauge at each oil change for peace of mind.
Old 12-06-2014, 03:16 AM
Received 10,477 Likes on 6,918 Posts
Clarke,
Its a Jaguar, have some faith my man.
That in and out of the sender is serious drinking time invasion, HAHA.
Seriously, these things are bullet proof, and in all my years I have only seen one bottom end issue, and that engine was plain and simple OUT of oil, dumb owner. He would have killed a Commodore still under factory warranty, trust me.
When it hits 700K kms or more, then maybe a little bit of "thinking" might creep in.
o1xjr (12-06-2014)
Old 12-06-2014, 04:03 AM
o1xjr's Avatar
Originally Posted by Grant Francis
Clarke,
1.Its a Jaguar, have some faith my man.
2.That in and out of the sender is serious drinking time invasion, HAHA.
1.Never worried about oil pressure on the last 26 cars, so all will be good. Just want the gauge doing what it should.
2.Not really, I was having a few cold ones while I did it! , in true Aussie fashion.
Grant Francis (12-06-2014)
Old 12-06-2014, 10:09 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Some time back, the guage on my S# was showing low OP. As I had read of the jaguar sensors being a bit flakey and my LT1 hydraulic lifters were quiet, I was reasonably sure OP was OK.
But, to be sure, I went shopping for a mechanical guage. Amazingly, no luck. So, I got an after market electric guage and sensor kit. Sun Pro brand. sure, enough, I plumbed it in and the numbers were just right.
A neat unit.
But, a bit clumsy. A nice original NOS sensor from David Boger and all is well there.
If and when that sensor conks out, mebbe in twenty five years or so, I'll install the Sun Pro unit. Or will I???
Point, find an after market sensor if a Jaguar unit is out of budget.
Carl
Old 12-06-2014, 10:52 AM
Roger Mabry's Avatar
Default Clean the PCB contacts and mounting screws and grounds
I finally got my S1 gauges working correctly by cleaning all the copper PCB connections, the mounting screws, washers and nuts. Plus, the gauge
ground connections and tightening the mounting screws.
Made all of them work more precisely and even brightened the poor lights!
Old 12-13-2014, 01:57 AM
philipE's Avatar
owners manual says = 20w50
  #28
Old 02-08-2015, 01:39 PM
TheWarlock's Avatar
I use a VDO 360006 with an adaptor on the V12 engines, and it is sooooo accurate and being VDO is reliable. No reason it wont work on the 6cyl.
Attachment 99450
Thanks Grant, the VDO unit shows a M10x1 thread. Can someone tell me what the stock thread size is so that i can locate a suitable adaptor?
I have the same symptom as many others on my V12, the gauge appears to be reading low and the sender seems to be the most likely cause based on the comments here. No reason to go with a known poor quality oem part
Old 02-09-2015, 01:52 AM
1/2" NF.
I used an old oil drain plug from a V12, or an XK engine. Drilled a hole in it and tapped a thread. Most GM/Ford/etc use a 1/2" NF drain plug.
When threading the assembly into that alloy pedastal BE CAREFUL, as the threads are only alloy, and OLD, and can strip. There is simply no need for Gorilla tight. A NEW copper washer, and simply "nip" it up, always worked for me.
toronadomike
08-07-2022 03:41 PM
rsa760041
23
09-25-2015 01:33 PM
Dymaxxion
09-04-2015 02:40 PM
Jag-o-nomic
09-04-2015 03:07 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
Quick Reply: Low Oil Pressure, XJ6
