Lower ball joints
I think one-piece ball joints are the norm. I just got a pair from Welsh because I have to replace mine (and I was going to start a thread asking advice on doing them). When I was shopping around, almost everyone had once-piece joints. I think I only saw one supplier who had the old-style kit.
I believe the old multi-piece unit was discontinued and the new one-piece (which I believe is the same as the XJ40's) is the current standard.
Received 9,301 Likes
Received 10,916 Likes
Correction. I wasn't thinking.
The seat is in the 'vertical link', #15 in this illustration
https://www.jaguarclassicparts.com/u...-carrier-front
It's certainly easier to drive out the old seat with the vertical link on the workbench but it's doable with it still on the car.
using a hacksaw or Dremel to make a slice through the seat makes the job a snap. Just a couple taps and the seat collapses on itself and falls out
Since you'll have the lower ball joint disconnected it isn't but a couple minutes more work to unbolt the upper ball joint and so you can take the vertical link over to the workbench
level 1 (05-01-2017)
Lower ball joints, however, do require a spring compressor.
GREAT CARE MUST BE USED WHEN RELEASING THESE SPRINGS. IF THEY'RE CARRYING 1000 POUNDS EACH, JUST THINK WHAT A WILD SPRING COULD DO TO YOUR BODY ON IMPACT!
That being said, we did it, had No trouble at all and here I am to tell about it.
I replaced my Series 3 lowers with the later lower ball joint, (XJ40 and subs), without using a spring compressor.
All I did was support the car under the spring pan. First you jack up as normal then lower the car onto a pre-prepared stack of short wooden planks below the spring pan. This takes the weight off the lower joint which can then be unbolted and removed, then the ball seat driven out of the hubcarrier. After this it's a simple job to bolt on the new joint, making sure it comes with the shorter screws, those of the originals are too long. No need to use a tab washer either, as the new screws come with thread lock compound on them.
You need spring compressors to remove and refit the rear springs. However the front springs are recommended for the Jaguar compressor tool that costs a mint, but there is an alternative as outlined by Doug on this forum. You obtain four suitable lengths of threaded rod of the same dimensions and threads as the screws on the lower spring pan. These secure the spring pan to the lower wishbone, so take the full spring pressure. Removing a single screw, you screw in the threaded rod, then run a nut up it to the wishbone, and tighten, but not too tight. You and then go round each of the other screws in turn doing the same, but dont take out more than one screw at a time. Once you have the spring pan secured by the nuts on the threaded rods you can unscrew the nuts gradually a bit each at a time until the spring pan lowers and the spring itself is decompressed, then undo the nuts finally and remove the spring. These threaded rods have to be quite long, and it will seem as if it takes forever to undo all the nuts, but it's a load cheaper than buying the special tool ! Here in England, the Jaguar Enthusiasts CLub have a hire service for the spring tool.
ronbros (05-09-2017)
