Lower steering column knuckle
Exploring my steering system tonight, as it was feeling loose. Discovered that the u-joint bolts were less than finger tight (loose clamps and bolts has been a common refrain as the previous gentleman did not drive the car much after he undertook initial
restoration), so that seems to help.
Below is a picture of the lower steering shaft knuckle. The joint that I have circled has some side to side play in it. Is that normal, or does it indicate wear?
Received 10,978 Likes
Received 9,436 Likes
I'd always thought that the unusual design of the Jag's u-joint was meant to accommodate the rubber-mounted front suspension cross member. The u-joint can move axially to let the front suspension move around on the rubber mounts without translating that movement into the steering column. The joint should move in and out freely but have no slop in the u-joints.
But ones I've pulled off of junk cars are usually stiff in the axial direction and give me the impression they didn't actually move much in service.
As an aside, I recently built a hot-rod with a Jag suspension and I used the Jag rubber mounts to install it in the new chassis. I saved the original Jag joint, but used a straight u-joint to couple the steering shaft to the Jag rack and pinion - I have not driven it yet, but I'm curious to see if the rubber mounted IFS translates any motion up into my steering column (column is out of a Cadillac)
I'd think that David at everydayxj.com would have one if yours is knackered. If you want to experiment, ujoints with the Jag's spline are available from Sweet and other manufacturers. I believe the MGB steering joint is the same spline as the Jag's too.
Anthony8858
09-05-2016 10:48 AM
Addicted2boost
03-27-2016 07:43 PM
2000ViperGTS
01-02-2014 02:56 PM
gabrielduenas
10-03-2011 01:18 PM
