Manual trans in your Jag
I have collected a 5spd manual trans & components to change my 73 lumped 350/350 into a 350/5spd. I've had numerous questions as to why I'm doing this. I'm 68 and grew up choosing my gears up and down. Like many things, you have to do it to understand it. Today, manual transmissions are found in very few cars, and this is very limiting to younger generations. I'm curious about others' opinions - pros & cons, memories and questions.... please respond.
Thanks, Jim
Thanks, Jim
Hi Jim,
Pros and cons ..
My S1 XJ6 has a 5 speed toyota gear box in it and I love it !..like you I grew up with manual transmission so think nothing of it just seems the norm to me.
But compared to a S1 XJ6 with an automatic box..the autos do seem to have a smoother more luxury unhurried feel to them..
My MG has an electric overdrive on 4th gear which I feel gives the best of both worlds ..to pass at highway speed just flick the switch and floor it !!
I think a lot depends on how I feel at the time !!
Pros and cons ..
andys-GR (01-05-2018)
Received 10,952 Likes
Received 3,979 Likes
Received 9,414 Likes
I grew up with both and I have both now. On the farm the cars and pickups were auto, the big trucks manual.
My Datsun roadster had a Toyota 18RG/5-speed (old school) and I Loved going through the gears! I can't imagine that car with an auto trans the way I drove it.
My work truck is a 4-speed with stump pulling Granny Compound Low (I actually pulled a farm plow out of a client's yard with it once). I can't imagine an auto trans in that vehicle.
However. I would not want a manual in Nix. She is in a Completely different class of car from anything I've ever driven. When I drive Nix I don't want to be changing gears and all that mundane stuff. I want to be setting up for the next curve, calculating how fast I can take it; or I want to be lazing along with no particular place to go, enjoying the pure luxury of a classic ride.
When I'm in town my truck gives me quite enough driving in traffic with a manual, so unless it's work, I'm either driving Nix or the Adequate Vehicle (Sonata) with 4-speed auto.
Received 6,327 Likes
Jim,
I collected most of the pedal box parts back in the late 90's, one thing I don't have is the brake pedal for a manual box. I can't tell if the auto has to be bent (roughly an S shape) to work with the clutch pedal or if it's the same shape as the manual. The pedal pad will have to be trimmed of course.
The other thing is the clutch pedal I got has a detachable pedal pad, an older design I think. Of course I wasn't able to source the pad itself.
Also, the clutch master is an older vertical BL piece with the reservoir integral to the cylinder. I think I'll find something else, maybe a wilwood or preferably a more common british master.
Any ideas here? Words of experience?
As for auto boxes... I could live with them up to the 4l60 gm box. At that time it seems all the US makes decided to program their automatics to irritate the living hell out of this one guy down in south Ga. I suppose it's all in the name of posting mpg numbers, but when I push on the damn go pedal I need it to go NOW. Of course it doesn't, then you push more (by now you've been creamed by a semi) and the sob downshifts three gears! I despise them. Fords too, and Hondas!
I drive my truck in tow-haul mode most of the time when I'm in town. Screw gas mileage, it's cheaper than therapy...
But at least it's uncomfortable.
Received 2,399 Likes
I had to learn to drive two systems before I could get my license at 16.
A long time ago!!!
My "learner car" in more ways than one, was a 23 T Ford roadster pickup. Two speed planetary, as used in modern autoboxes????
Henry provide three pedals to drive the car. left to right. 1/2 down, meant neutral. All the way got first. Center pedal got reverse. But the other foot needed to push the left pedal half way down. Right pedal engaged a band on the transmission drum to "brake" the car.
Oh, and a hand brake lever to the left. All the way forward, high gear.
1/2 back, neutral. All the way back, neutral, "emergency" brake on the axle engaged.
Oh, the throttle was a lever on the steering column ust under the wheel. Gotta mess with that while the feet pressed pedals and he other hand messed with the hand brake lever.
Well, I and others messed with this "simple" and practical system.
Out with the "T' carb and in with a far better "A" carb. Throttle motion in a diferent plane? So, add the "A" foot throttle. it fit almost perfectly!!!
Oh, another added bit. A two speed "Ruxtel" rear axle. Another lever in the center of the floor board to shift it. Aha, now have four speeds forward and two in reverse!!! mess with it a bit and it would "torque
shift". I could beat any one "speed shifting" in a conventional box!!!
Oh, oh, the Texas cop refused to ride in my t for my license test!!!
So, dad gave me lessons in the family 38 Dodge and at his job in the assigned Dodge "weapons carrier"!!!
Decades later, son ready to drive. Vehicle. A 57 Ford pickup. Powered by a Thunderbird 312 V8. But with a four speed. Granny low. First lessons in the old oil field roads in the hills of LA's San Fernando valley.
His present ride. A big old Dodge 3/4 ton 4x4. Cummins powered and four on the floor. It will pull anything, and often has... 300.000 miles and counting and running like the work hose it is....
Yeah, before my days are over, I's like to shift some more gears.
My "hot rod of the 40's" project had three on the floor and a warmed up Flat head Ford V8. Jumpy low meant quick foot action. Not too mention the poor idle of twin carbs. But, once in to 2nd, hang on....
LnrB: Might even be more fun... Go into that turn in 4th, drop to 3rd and at the apex, stand on it.....
Carl
A long time ago!!!
Carl
ronbros (10-10-2016)
Received 1,236 Likes
when i was young and dumb, and full of %%%, of course i drove manual shift!
but now that i'm much older, i like a good 4/8 speed auto, especially in heavy traffic!
and sport mode is awesome.
what are we gonna do when cars are Electric, with no shifting at all!
read where Germany is gonna outlaw ICE cars within 10years(internal combustion engines).
Modern 6/8 speeds with their tight converters and torque management tend to up-shift early to save fuel and feel lazy yet busy to me. I just took my 405 HP Escalade in to the mountains on a family trip and it was more enjoyable and controllable to drive in manual shift mode.
I still prefer a manual for sport driving. So a T56 is the best bet. Autos are heavy and parasitic and have to be setup to perfection to survive high HP builds.
So...I just purchase another Coupe. This one actually is rust free. I plan on introducing it to the LHD pedal box I just purchased. Question is what engine to stick in front of a T56? Big block? Turbo LT1? Or one of the SBC's I have laying around.
ronbros (10-13-2016)
Well, auto boxes do have a place. A couple of times, was stuck in bumper to bumper, stop and go traffic on our old Bay Bridge.
Clutching in and out just about got the best of my less than perfect
left knee. Thanks to "Choclate" my burro at about age 14. he rolled over on it, ouch1
Elinor:
Did the bit farm trucks have a little "trigger" jut under the shift knob to shift a two speed rear axle in and out of low. "Pull" the trigger, lift the throttle foot, it shifts, back on the throttle. Same sans trigger pull to up shift!!! Slick...
My "T" with the Ruxtel worked that way, but with a lever. Torque control...
Carl
Elinor:
Carl
Elinor:
Carl
Elinor:
Carl
Elinor:
Carl
Elinor:
Carl
hey carl, remember the guy with "i had twin syphs and a COLUMBIA BUTT" for you guys that dont dig the jive, "thats two carburetors and an OVERDRIVE"
ron
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
