Mk 10 SU's on S1 XJ6
Mike,
MK10 3.8ltr manifold will not match the 4.2ltr head, I THINK, but that is a tad fuzzy in the brain now.
The MK10 4.2ltr set up will fit the head, BUT, I think the rear carby is going to get fouled on the brake booster, and if it clears, JUST, the air cleaner will be fun, NOT.
Nothing is impossible, but I reckon a very tight squeeze is ahead of you.
No worry's Grant - Actually I have a black Victoria number plate on the front of my car so if you saw it you would think it was a RHD from Oz. Lived there for quite a while - magnificent country. I think there's a pic of my LHD Australianified XJ6 in my pics section.
I have both a 3.8 and 4.2 Mark 10 3 SU setup - just got the 4.2 and I found some cash so I'm gonna have it professionally rebuilt for the XJ6. I've heard alot of things about the conversion and sometimes I've heard that the front carb may interfere with the bonnet (nothing definitive though). I know that if you try to use the original XJ6 header tank the filler neck will interfere so some modification is necessary. Not worried about that though as long as the carbs themselves will fit. Linkage is gonna be a bit of an adventure because I have to maintain the downshift solenoid switch for the BW model 12 - I'll make it happen though.
~Mike
~Mike
baskervillema
10-01-2015 06:43 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
