Ton lead off my Mother has already been here and many of you have helped her, I'm not sure of where her post is.
So we have a 91 XJ6. My mother ran over a curb and says she scraped it... I've inspect the undercarriage and fine no decernable damage.
On to the withering, suffering, no start.
I bought the car for her in 08 or 09... she always wanted one and I always dreamed of buying her one. So when I found this black Beauty I jumped on it. It had a battery terminal disconnect from the start...
Since 08/09 I've replaced the battery maybe 5 times. One of us will drive it and forget the knob or it touches something and drains.
Like most Jags she has some issues. I don't know that much about them, though I have been working on this one for sometime. Im going to list out the symptoms and the issues so that they can each be reviewed by the forum and advised
1. Issue: I have been gone for 1 year... (don't ask... a woman) well My mother says I'm the last one to put gas in it. And after draining it, there is 5 gallons of clean, but old 91 octane.
1. Solution : added 5 more gallons of 91 and suggested amounts of Seafood and Heet for the quantity of fuel and then added a little octane booster to keep it high.
2. Issue: Large Brown Plastic Connector near battery is melted and dead ends into a melted wad of wires.
2. Solution: ??? Melted and dead end connector
3. Issue: The gas cap and the fuel filler tube flip lid have rust. You'll also notice the horrendous looking clear liquid nails job I did on the filler neck gasket. It had rotted and was getting the trunk wet and causing mold. I'll get a new one sooner or later.
Rusty fuel fill
3. Solution : brushed rough rust off, grinder and sealed cap. Liquid nails in the gasket.
4. Issue: 3 different connectors in the trunk, the drivers side panel, have no mate, seemingly no where to go.
4. Solution : ???
5. Issue: air intake tube connecting mass air meter to 90 plastic elbow had 4 inch crack.
5. Solution : epoxy and tape. We don't have the $35 for a new one right now
Also taped and goued
The car you are describing is an XJ40, not a Series III V12 Sovereign, so it is not covered by this particular forum - totally different cars. You'll get a proper answer to your question from the XJ40 list.
Ummm... don't remember asking what kind of car I had. I'm fairly certain I know. Even told you in the title; a 1991 XJ6 Sovereign. Could we get back to the point at hand? The car doesnt start
This section of for the earlier XJ6s. Most of the people reading this sections have little or no experience with the later XJ6s such as yours.
Your model is covered in the XJ40 section as Gregory mentioned. The people there have more experience with your model are most likely the best source of answers for particular questions .....such as wiring and connector mysteries.
Have you checked for spark? That's always a good place to start
Hello, Kristoff,
As I explained to your mother when she first posted here, I know it's a bit confusing when they put an Xj6 badge on the trunk (one of Jaguar's marketing ploys perhaps), but that car doesn't even have the same engine as our Xj6 series 1, 2, 3 cars, and is completely different in other aspects as well.
Pleased to see you have apologised for this rudeness and have also now copied your original post to XJ40 forum.
