Moonroof Question
It's in the trunk, but the gear that moves the sunroof cables is only accessible by removing the rear seat. If you unscrew the bracket that holds the cables to the gear and then leave the cables free and loose, you should be able to test the motor.
In my case the switch was bad in one direction.
Received 2,637 Likes
When diagnosing your motor fault be aware that the motor will have a positive feed to each terminal. The motor is energized by removing the positive and replacing it with a negative (EARTH) feed on one terminal. Reverse is obtained by swapping the current feed.
bob gauff
P.S. The XJ6 has a SLIDING ROOF or SUNROOF. A Moonroof is usually a designation for a clear roof panel.
bob gauff
Prior to replacing parts, have you checked all the connections in the circuit? If the breaker has been tripped, there is usually a reason: either high resistance or a short to earth (ground) within the circuit.
The breaker can be checked with an ohmmeter (while disconnected from the circuit) for continuity.
NBCat
NBCat
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
