My first Jag
This past November I bought myself a 1985 XJ6 so I thought I'd share my story so far. I picked it up from Craigslist for $1000. When I bought the car it had no exhaust, the previous owner had bottomed it out and broke off both mufflers. The alternator was dead, so the owner was using a trickle charger to supply the battery with sufficient power to get him back and forth to work; once he got to where he was going he would replace the battery on the trickle charger until he was ready to drive again. In the midst of the alternator issues he'd bought a new battery which was not only the wrong group rating but was a top-mounted post battery instead of the proper side post, so it was almost 2" too tall and would arc when he slammed the bonnet down on it (he said it wouldn't shut without slamming it, the wrong battery being the reason). Since then I've had 2 new Magnaflow mufflers installed with new aluminized stainless steel piping, and the stock curved tailpipes were retained and cleaned. It has a new alternator, new proper battery with new terminal post leads, new Champion spark plugs and new plug wires/rotor/distributor. Total investment so far including purchase price is at about $2300. A few remaining flaws include potential wiring issues with tail/side marker lights, needs steering boot replacement, and a slight valve seal leak that for now will hopefully be slowed by using 20W50 grade motor oil. Other than that most everything on the car works, aside from the cruise control and the back driver's side window. More updates may follow, in addition to more questions as I delve deeper into working on my first project car. Thanks for reading, and should anyone have suggestions/comments, feel free!
Received 6,327 Likes
Sounds like you will have a nice car there. Look forward to hearing your progress.
When time allows drop by the new member area and post an intro.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Received 2,399 Likes
Kudos, indeed. A great way to commence the Jaguar adventure. and, an additional kudos for rescuing the car from the ".... " of the PO!!!
Not a criticism, merely curious. why do some folks obliberate plate numbers?
If you don't have one, get a couple. VOM's. One digital and one analog. and, solder up a test lamp.
Also get Jaguar Publication S57. The electrical schematics for your car.
Jaguar mantra for electrics. Clean, tighten and lubricate.
Ground points in poor condition account for m any electric anomolys. Find trhe ground for the errant circuit, apply the mantra and a lot of the time, it will light up!!!
Enjoy!!
Carl
r
Enjoy!!
Carl
r
Received 9,302 Likes
That car looks almost exactly like mine including the interior, except you have a sunroof and the steering wheel got put on the wrong side. I think the colour may be Cranberry Red, which is more of a Maroon/Burgundy as you say.
no wonder I got an antique plate! 30 years old already! 31 because Jaguar built those cars 1 year ahead of their release for sale.
VinnyT
69
05-17-2021 09:30 AM
