my heater is blowing cold air
the under the radio slider I keep centered in my car, it really does nothing to affect the air temperature, its purpose is more to affect the air temp balance between the upper and lower vents, and then, a very subtle effect at that. Make sure the cooling system is full, set system to AUTO, set TEMPto 85. Remove cap at coolant tank. Start engine,allow to warm up, takes a while. Then watch the coolant level at mouth of tank, should remain full as engine heats up to normal, about one inch below the top of the tank's filler neck. If no heat after that check, next check will be the Heater Valve.
Hafrod (02-11-2016)
Received 2,399 Likes
OK, after some looking, I found the two vacuum hoses that go beside the battery box and down toward the lower frame rail. The big one of the two is not hooked up. I also see the check valve on the bigger hose. I removed it and cannot blow through either side. I have it soaking in hot water right now. The heater valve actuator moves when I suck on the hose. Got to go get more vac hose in a minute to at least try to fix one thing today. Lol. Do I need the check valve?
OK, I got the 2 vacuum hoses replaced and plugged into the port at bottom of firewall. I could not see the port till I climbed under the car. I put it on auto and 85 as suggested. The car got to temp but still blowing cold. I removed the passengers side front console panel and found an inline fuse. I pulled the fuse and checked it. It was good. I seen a linkage setup so I lubed it and moved it around. It actually seemed stuck. I also unplugged the two large wiring connectors to check for corrosion. They looked clean so plugged them back in. I started the car again and the linkage started moving slowly. It was moving back and forth real slow but I instantly started feeling heat. I turned the temp dial all the way to cold and it quit blowing hard. I turned it back to 85 but it never blew hard again. It was like it was on low speed. I switched it to high and it will blow full blast though. So I do have a heater but on auto it won't blow high speed. I'll go back out and try again on auto in a minute. The linkage moving back and forth was kinda weird. Shouldn't it move up or down only?
Received 10,892 Likes
Good work ! Progress ! Maybe the servo and all the trap doors just need exercising
Either there's a problem or the auto system is looking at cabin temp versus desired temp doesn't see the need to run the fans at high speed
Not 100% sure what you mean but the linkage is operating 5 flaps in concert. The links and levers operate off cams in the servo motor so the actual movements might look a little weird...sort of robotic, I guess
in HEAT mode, the blowers do not run higher than 3rd speed, the 4th speed is only available n COOL mode.
the check valve: you should be able to blow air through it one way but not the other, if both sides are closed, the little ball inside might be stuck, putting it in warm water with a little detergent for a while should dislodge it.
YUP, absolute progress. Getting the right hoses on to the teeny spigots under the battery is a feat in it self !!! No visibility, tactile only!!
The one way is essential. Engine pumps out air and creates the required vacumn. Valve prevents it from bleeding back! Resevoir stores vac!!
When mine has acting up and I want warm air, I just select defrost.
Warm air in to the cabin, where ever is fine. Lately, it ahs done just exquisite. Auto selection a real treat.
I did modify my system. I added a manual valve to the heater hose not controlled by the vacuum actuated valve on the fire wall.
A summer/winter setting, if you will. No hot water in the matrix for
summer powered ventilation. Open in winter and it is nice and cozy inside!!
Carl
Carl
rickpwilson
08-20-2020 10:08 AM
