Mystery Electrical Items on my Series 1
Hello everyone. I'm trying to trace down some electrical issues (yes, I know - a never ending problem) and I noticed I have two fan wires unplugged right next to these two white ceramic things. Can anyone tell me what they are and what purpose they serve? Also is there a modern solution that I could replace them with? Thanks!
Received 2,399 Likes
LT1 jaguar (05-22-2022)
Received 1,096 Likes
I don't have experience with S1 XJ6 but following is a guess
I suspect they are ballast resistors and part of the fan speed control.. The more resistance you put into the power going to the fan the slower it will go,
eg.
fan speed
high- no resistance
medium - one resistor
low-two resistors
eg.
fan speed
high- no resistance
low-two resistors
eg.
fan speed
high- no resistance
low-two resistors
eg.
fan speed
high- no resistance
low-two resistors
On later S1s (not this one) there are indeed three speeds, just as Bill suggests. There are two separate resistors, but they are located in the plenum so that they receive cooling air. Low speed is the default when the fascia switch is off but the AC is switched on. Medium is is the fascia switch low position (which puts the two resistors in parallel), high is direct 12V to the motor via a relay. IMHO.
The following 3 users liked this post by Robert Wilkinson:
