Need an engine for a 1976 XJ6 Jaguar
Guest
Posts: n/a
RE: Need an engine for a 1976 XJ6 Jaguar
Are we talking about swapping the entire engine and transmission, or just the block, etc? Your 76 XJ6 is a carberator engine. The 85 is fuel injected. Guess if you had a doner car you could swap the engine from the 85, along with various harnesses, and fuel system, such as gas return lines, pump, ECU, etc. It wouldbe a big project, but, depending on your ability, do-able. But, since your asking this question, it may be more than you would want to try.
Guest
Posts: n/a
Yes Steve, I thing maybe I have to install the old intake to this engine, I hope It will be no problem. Keith, the guy selling the car, installed in his car an 350 engine all chromed, hi fixed the car for a showrom, he removed engine, transmision, power stering, radiator and parts for this engine, i hope I'm getting everything I need, everything was working perfect before he removed it, the engine has 90K, Will see it tomorrow.
rusty37
06-07-2016 04:43 PM
SingBlueSilver
08-27-2015 02:20 PM
1976, cars, chevy, conversion, engine, fuel, installation, jaguar, johns, rebuild, review, system, transmission, xj6, xj6l
