Need Help - contaminated fuel system
Old 07-14-2012, 07:59 PM
Jose's Avatar
Received 2,444 Likes on 1,839 Posts
Haynes and Chilton car manuals are jokes !
Old 07-14-2012, 08:50 PM
Doug's Avatar
Received 10,875 Likes on 7,152 Posts
^ +1
Old 07-15-2012, 03:28 AM
Fraser Mitchell's Avatar
Received 2,451 Likes on 1,949 Posts
If you have no fuel return system in operation, where is the blow-off going from the fuel rail pressure regulator ? The basic method of operation is the pump over-supplies fuel, and the pressure regulator on the fuel rail regulates the pressure in relation to manifold vacuum, with excess fuel blowing off back to the tank via the return system. The effect is that the fuel pressure differential over the manifold vacuum is always the same.
This sort of thing is no longer done with modern electronics able to control the fuel pum p directly, as on my own x350 model XJ6.
Anyway, I wish you luck with your car, and hope you get it fixed OK. These early EFI systems can be a bit troublesome and the age doesn't help.
Old 07-15-2012, 06:36 AM
Jose's Avatar
Originally Posted by Doug
^ +1 Cheers DD
if not jokes, Haynes and Chilton car manuals are insults to any Pro Technician or Trial-n-Error-nician !
Old 07-15-2012, 07:04 AM
ooootis's Avatar
+1 on Fraser comments. Glad to see you bought a pressure gauge. To compliment your pressure gauge, a vacuum gauge would also help for adjustments.
Old 07-19-2012, 01:34 PM
tjwiseman's Avatar
the maf meter adjustment made no impact what so ever.
the relieve of the pressure regulator goes to the fuel pump
its how i got it, i swear.
toronadomike
08-07-2022 03:41 PM
dsnyder586
04-04-2019 02:38 PM
ccfulton
09-20-2015 05:15 PM
deanh
09-06-2015 08:20 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: Need Help - contaminated fuel system
