Need help diagnosing HVAC problems (it's dead)
The HVAC on my '83 XJ6 doesn't work. Turning the fan selector doesn't turn on the blower motors, and turning the other knobs also doesn't seem to make any noise or causing anything to change.
Is there a list of things to check first? (Where are all the fuses?)
I have a multimeter and a spare AC amplifier that is supposedly from a working climate control system in a XJ6.
Received 10,975 Likes
Fuses are a good place to start.
There should be two in the RH fuse box....can't remember the fuse numbers off hand
There's another clipped to the side of the climate control case, behind the RH cheek panel of the console. It'll be on the brown/yellow wires
The fourth is on the amplifier ground wire, behind the LH cheek panel
With the fuses bear in mind that they don't have to be blown to be inoperative. Dirty/corroded end caps or a broken wire under the end caps are common...as are corroded fuse clips/contacts
If that checks out go ahead and try the amplifier. No need to remove the old one. Just unplug it and plug-in the new one
amcdonal86 (01-20-2012)
99xk8guy
06-05-2023 06:28 AM
KarimPA
09-12-2015 08:15 AM
