need help indentifying interior color
thank you. I have been on your website and I have not been able to find two obscure parts. Can you help?
1. The 3rd rear brake light in the window is missing therightside hook that is attached to the window. Do you have one?
2. The lamp under the dash just above the middle vent the cover is missing Do you know which part I need?
http://www.captainjaguarscathouse.com/Trim_Codes.htm Try this link for the trim codes, should help. Now, to locate the trim code, look under the hood, on the passenger side, on the fender lip. There should be a small tag with the code on it. Let me know what you find out. On second look at your photos, yours might be a tad lighter than my Bisquit, so it could be the doeskin.
trosty
01-08-2016 06:43 PM
42Ajd
12-30-2015 09:45 AM
Ipc838
09-13-2015 03:27 PM
