Need help with tappet stakedown kit
#41
#42
Hey Guys,
I had a leaking Cam Cover so decided to pull it off and take a look underneath. I could see that all bar the forward two Tappet Sleeves had received some kind of contact damage from the Camshaft. I already had a stake down kit ready to go, so set about cleaning it all up. This is when I found a piece of Tappet Sleeve shrapnel from the rear most Ex Valve.
I'm going ahead with the stake down kit to stop matters getting worse, but I'm worried that the 1/4-28 UNF Cap Screws that have been supplied aren't up to the job? Should I go with 1/4-20 UNC instead?
Has anyone used UNF and had bad experiences?
#43
