New bush front suspension
- you have to loosen the circular clamp (part of the actual subframe) that holds the bush. You can just gat a spanner on the top of the bolt, the bottom nut is easy
- undo the huge nut and bolt through the centre of the bush
- tap out the bolt, then the old bush.
- ensure you get the sleeve out of the old bush and put it into the new one
- replace the bush and insert the bolt (might need fiddling a bit to get it through the sleeve)
- tighten the bolt
- then tighten the clamp.
