New and improved bonnet stay
Old 05-23-2019, 08:32 PM
Yellow series3's Avatar
Default New and improved bonnet stay
Last fall we were talking about a bonnet support or stay system that would hold the hood open at a wider angle. After a lot of hours and prototypes to get the geometry just right I have a new design you might like. Here are the benefits to the XJ6 owner:
1) 15 minutes to install
2) Completely reversible
3) Securely holds the hood open at the maximum angle allowed by the hinges
4) Very easy to opperate
The factory hood stay design holds the hood open at 34" measured at the corner of the hood. This new design holds the hood open at 50" a 47% increase.
The assembly consists of three pieces that need to be fabricated. Two of them can be made with common hand tools. The third has a simple milled slot that requires a milling machine. Very few Jaguar enthusiasts own a milling machine but every machine shop has at least one so it should be a simple matter to find someone to produce the pieces. All of the material and fasteners are available at Lowes or Home Depot for less than $2 plus a special knob that is available for $3 retail.
Below are photos of the plans. Then I'll post again and hopefully get the printable pdf file posted. Also, I'm going to post an 8 minute YouTube video that shows you how it operates. I have been testing the prototype for about a month now. I hope it works as well for you as it has for me.
The following 11 users liked this post by Yellow series3:
Andy Paine (06-01-2019), Daf11e (05-24-2019), Doug (05-24-2019), Jag7651 (05-24-2019), LnrB (05-24-2019), LT1 jaguar (05-23-2019), Mike1610 (05-26-2019), Mkii250 (05-26-2019), motorcarman (05-24-2019), XJDanny (05-24-2019), yachtmanbuttson (05-24-2019) and 6 others liked this post. (Show less...)
Old 05-23-2019, 08:34 PM
Here is the printable pdf file.
File Type: pdf
The following 5 users liked this post by Yellow series3:
David84XJ6 (05-24-2019), geneo (05-24-2019), Jag7651 (05-24-2019), LnrB (05-24-2019), motorcarman (05-24-2019)
Old 05-24-2019, 08:22 AM
Jose's Avatar
Received 2,458 Likes on 1,848 Posts
yes, very well done.
Old 05-24-2019, 10:03 AM
pjprofili's Avatar
Looking forward to the video!
Old 05-24-2019, 11:36 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Very well done. I saw a similar device decades or so ago on another forum.
I removed the "monkey motion" version early on to get a wider opening to work under. I use a chunk of pipe to protect me from errant breezes.
Your version could be made sans a mill. I'd miss the power "hack saw" that I gave to my son. An HF sourced device that resembled a band saw, but that could operate in a vertical or horizontal position.
As to the log slot in one part. drlll a series of holes and then clean up with a sharp chisel and file. Drill press nice, but a hand drill and vise will do. My hand grinders and cut offs and possibly my belt sanders could come in play..
Carl
Old 05-24-2019, 12:46 PM
Carl is right, you can do it by hand if you are patient.
Here is the video showing it in action. Staring yours truly.
Jeff
The following 7 users liked this post by Yellow series3:
Andy Paine (06-01-2019), danielXKR (02-19-2020), Jag7651 (05-24-2019), LnrB (05-24-2019), Mike1610 (05-26-2019), Mkii250 (05-26-2019), XJDanny (05-24-2019) and 2 others liked this post. (Show less...)
Old 05-24-2019, 12:50 PM
yachtmanbuttson's Avatar
Hey look what I just found from our very own Jeff - Yellow series III. Great Job!
Old 05-24-2019, 05:19 PM
pjprofili's Avatar
Why the long slot? From the video it didn't seem to need all that distance, if any.
Old 05-24-2019, 08:38 PM
pjprofili, the closer it gets to fully closed the more it travels. When the hood is closed it is a very tight space and getting it to fold up and not run into the radiator support or hood itself was a challenge. In building my test sets this length slot seemed to work best. I am very interested in people experimting with the design and improving on it. If you build something that works better or is easier to build be sure to post your results.
Old 05-24-2019, 08:41 PM
Doug's Avatar
Received 10,920 Likes on 7,174 Posts
Great invention.
If you're the enterprising type I'll wager an all-in-one kit would sell like hotcakes!
Any problem with the hood colliding with the front bumper?
Old 05-25-2019, 07:35 AM
Jeff - are you getting my private messages? I seem to be getting yours, but I don't see a trail of mine in this forum in the private messages section.
Bill
Old 05-25-2019, 01:20 PM
David84XJ6's Avatar
Jeff,
I put your dimensions into a CAD drawing and got a machining quote for $19 for Cold Roll Steel and $ 27 for Stainless Steel, for one set (3 pieces) of 20 sets. I think you have a winner. Hardware, plus shipping and a little for a night at the Pub.
Good update for S3 owners.
Rgds David
Old 05-25-2019, 04:41 PM
Wow. That technology is great. Things certainly have changed. Back when dinosaurs roamed the earth I graduated with a degree in Industrial Design. We drew everything by hand in pencil and then they made blue prints (which were actually blue). That process used ammonia and smelled to high heaven. Then I went into sales and marketing for 40 years so technology left me back in the stone age.
I have a question. I have two series 3s so I know it works on that model. Are the hood stays the same for series 1 and 2? Anybody have experience with all three series?
Thanks to everyone for the kind words regarding the design.
Old 05-27-2019, 06:18 AM
iramphal's Avatar
I'd be happy to purchase one if a set is made!
Old 05-27-2019, 08:05 AM
Doug's Avatar
Add my name to the buyer list !
Old 05-27-2019, 11:15 AM
Received 9,342 Likes on 5,430 Posts
Originally Posted by Yellow series3
... Are the hood stays the same for series 1 and 2? Anybody have experience with all three series?....
I can't speak for Series 1, but I drive a Series 2, which hood stay I have ditched in favor of Nothing as the hood stands quite still and stable, not touching the bumper without it (I did keep it though, Just in case).
There's a derelict Series 3 out back which I just checked, and the hood stay is identical.
And, you can add me to your list of customers.
LT1 jaguar's Avatar
Received 1,105 Likes on 610 Posts
I would be happy to buy one too. My S3 came with no engine and the hood was off. I can see on your video that I would not have been happy with the factory hood opening if I knew something would allow me to open it wider.
Dave
Old 05-27-2019, 01:19 PM
sanchez's Avatar
add me to the buyers list also
Old 05-27-2019, 02:04 PM
XJ6Paul's Avatar
I'm in for a kit please if someone makes a batch.
Old 05-27-2019, 05:59 PM
pjprofili's Avatar
Sounds like there's likely enough interested people to make this feasible. I'm also interested. I think I'd prefer stainless too.
Quick Reply: New and improved bonnet stay
