I have come to the conclusion that no two XJ6s are the same. So a little tweaking might be required but spacer washers should get it lined up.
Bill, when I was endlessly fiddling with the design I thought about a notch or detent to get it to work without a knob. I wanted to not go wider than 3/4" for the material, if there was a detent I felt it would weaken the piece. Also, I wanted to keep it as simple as possible both to minimize manufacturing costs as well as to make it so it didn't require tight tolerances.
I highly encourage people to modify the design as you see fit and then build a prototype and test it. If it works out well be sure to post the results on the Forum with photos so we can all benefit from it.
Bill - Jeff
See attached for future "Locking Stay Concept" for extended maintenance periods (1/4 bolt or pin). I agree with Jeff that the current materiel is too thin to modify, the feature would have to be designed in. Also note forward link alignment issue, covered with longer bolt and extra plain Nut. This will prevent the bolt rocking in the bonnet bracket.
Rgds
David
Now if we could just get the boot/trunk lid to open a little higher...
an engineer friend in Tennessee did special Hood / Bonnet hinges for his MK-2, so I bet the concept can be applied to the bootlid hinges,
if you can figure out what he did !! HINT: it's a "pantograph" hinge.
Oh, I Like that!!
I'm SO tired of banging my head on the trunk lid, which no longer stays up anyway, so I have to prop it open with a broom stick.
Just this weekend I got my XJ^C back on the road and tried to put two golf bags in the trunk (mine and Barb's) with great difficulty. It would have been much easier with a lid that would open further. I guess I'm trying to make the perfect car! Maybe that's too big an ask! We sure did arrive in style though!!! The Starter drooled all over the car!
I don't have the answer to make it open wider but I developed a solution to keep it open as wide as it goes. A gas strut with the lower end mounted on a piece of angle iron and the top end on a steel strap bolted under the hinge. Total cost about $20. Open the trunk and the lid stays open and then closes easily. The part you need is here: Gas strut link
Jose
It appears that with the further opening of the lid, the center of gravity the Lid will move forward about 15". This may be enough to let the old springs do their job ???
Rgds
David
New and Improved XJ6 Bonnet Stay ... program update
17 units have been requested, 16 units shipped and 3 units remain available ..from the initial batch of 20 sets.
Thank you all for your support and helpful feed-back. This has helped others install their units, where minor tweaking was required for fit or alignment.
I will list balance of Stays on E-bay Monday. Will honor any request this weekend from Forum members.
Let's all give Jeff a round of applause, I think even William Lyons would have approved.
Best Regards David
PS: Bill, Jose and Elinor, have mentioned an interest in having a greater boot/trunk opening angle??? I will start a new thread on a "concept for combination bracket/hinge" for ~50% greater opening position, without broom handle.
