New Owner/Member Of A 87 XJ6
Good morning. My father just gifted me his all original(except radio) 1987 XJ6. It has 80,000 original miles on the 4.2L engine. I just got it home from Tennessee to New Orleans. It has a couple of minor issue that I could use some help with.
How to replace the drivers mirror? Mine just moves around and the switch will not adjust it.
The dash computer under the A/C vent comes off and on. Loose wire I guess.
Needs tune up. Dad doesn't remember the last one he did.
Stitching in front seats coming undone.
Does anyone know of a good mechanic or upholstery place.
Thank you and glad to be a part of this forum.
Received 10,989 Likes
You might get lucky here.
The mirror is removed by simply removing the two screws at the base. Now gently lift the mirror away....sort of gently teasing the wiring out of the hole in the door. With luck you'll be able to disconnect the connector....which is held together with a small wire-tie.
Don't let the wiring fall back into the door or you'll have to remove the trim panel to feed it back into the hole.
If you can't tease enough of the wiring out of the door you'll have to remove the door trim. But, in my experience you should be able to change the mirror working entirely from the outside
Often an erratic trip computer can be 'fixed' by simply removing and re-seating the connector. The computer itself can be removed by simply getting your fingernails under the edges and tugging outward.
But the computer itself might be on the blink. It happens with age.
Does the right hand mirror work now? Even brand new toggle switches work "odd"... have to press hard to make things work.. Did you try moving the toggle for that mirror several times in case it is just dirty?
The connector wiring is very short.. then pull apart the connection. Tie up the wires first with a light cord.. you do not want it dropping inside the door! The door panels come off easily enough but avoiding that job is the plan.
Mirrors are easily available.. so is the switch to adjust the mirrors on the door panel.
I just put these later S3 mirrors on my '71 Jag... easy to work on.
Good luck.
Andrew.
TitanoBlu (12-16-2017)
James Zimmerman
09-05-2017 02:57 PM
bainesjr
06-01-2013 09:04 AM
coloniamick
07-11-2011 10:41 AM
