New P/S rack - exciting times!!
Hi all
Almost ready to fire up the 86 with new rack, pump and hoses. Need advice please... What is best practice to fill P/S pump resevoir and do initial start?
Is there any sort of "priming" of the pump I need to do? Fill to level...rack to rack..then top off. I assume initial fill will drop level fast as hoses and rack fill up?
Thanks for help. Randy
Received 10,989 Likes
I fill the reservoir just to the bottom of the neck. Then start the engine and run for just a few seconds. The fluid level drops fast, as you mention. Top-off, then repeat once or twice. That should do it. Then purge air by slowing turning lock to lock a few times.
The important thing, as you're obviously aware, is to avoid letting the pump run dry while the engine is running.
Grant Francis (08-16-2021)
Received 9,472 Likes
Randy
You must lift the front of the car up so the wheels are off the ground, then top up the reservoir, then turn the steering wheel lock to lock about 20 times. Then follow Doug's prescription. This is the standard advice that comes with new racks over this side.
I might not have had the Banshee screech from the pump that emptied itself into the empty rack in about 2.5 seconds.
Greg in France (08-17-2021)
Front wheels must be raised for bleeding. New or rebuilt Racks always come with replacement instructions which say this.
I also use Teflon ( Plumber's Tape) at each hose fitting to make them leak-free.
Thanks all for awesome tips! While I have everyone excited about this final step I was wondering about opinions on WHEN to attach hoses to pump and rack.
My thoughts right now are to attach to pump and then install pump...then install rack and finally attach to rack.
But maybe order and when is not as critical
Randy
Randy
