New question
Received 10,916 Likes
Normal is 88-90ēC. The aux fan comes on at 94ēC.
A cooling flush (and all other routine service items) is a good idea just on general princples with a newly purchased used car....unless records indicate was recently done.
If you're really ambitious you can remove the radiator to clean it *externally* as well. The fins are usually clogged with leaves and debris.
