New steering wheel
New steering wheel
I contacted Ididit about replacing the steering column with tilt and a cruise control switch, it will not fit a Jaguar with a stock dash. The turn signal lever
would be too close to the dash to be safe to find and work properly. Our turn signal lever is bent about 45 degrees to clear the dash... theirs is straight.
So, I replaced the Grant wheel with another one that is dished 3 inches. Now with the column telescoped out there is clearance for my hands and it is
closer to me. Using the same brand allowed me to reuse the adapter and horn button with the Bow Tie emblem.
You can also see the cup bolted to the RH ash tray that holds my WeatherTech phone holder that is adjustable and allows the cell phone to be turned
sideways to use as a GPS. There is also another cup added to the center console top cover to hold a beverage... not shown in the photo.
The tablet in the center tray is for the fuel injection monitoring and note the added vents added to allow more air from the heating and AC system.
The GPS speedo is out of the dash and was sent to Speedhut for a pulse input for the new cruise control I will be adding. The cruise control switch
will added to center console where my mask is now laying.
Roger Mabry (03-06-2021)
Roger Mabry (03-07-2021)
