newbe help
Old 10-07-2012, 05:25 PM
tudstuen's Avatar
Default thinking its the ecu
what do you think
  #122
Old 10-07-2012, 05:51 PM
Jose's Avatar
Received 2,443 Likes on 1,838 Posts
Originally Posted by tudstuen
has power ...thanks Jose
still no start? have you removed and replaced the ignition cap at some point?
  #123
Old 10-07-2012, 06:07 PM
Jose's Avatar
here's two better ECU and fuel injection component diagrams that you might want to have blown up poster size at Office Depot: also do some reading at this page:
http://en.allexperts.com/q/Jaguar-Re...g-XJ6-dies.htm
tudstuen (10-07-2012)
  #124
Old 10-07-2012, 07:43 PM
tudstuen's Avatar
Default still no start
what do you meen by ignition cap?
  #125
Old 10-07-2012, 07:44 PM
tudstuen's Avatar
Default oh distributer cap
yes new and new roter and plugs and wires
  #126
Old 10-07-2012, 08:06 PM
Jose's Avatar
the distributor cap, where all the 7 plug and coil wires connect to the distributor.
is yours the type bolted with two screws?
are you 100% sure it is seated correctly? (even though the distributor has been mostly eliminated by now as the cause of the no-start).
  #127
Old 10-07-2012, 09:12 PM
tudstuen's Avatar
Default dis cap
yes 2 screws ,, im sure it is ,,but ill check again
  #128
Old 10-07-2012, 09:13 PM
tudstuen's Avatar
Default ecu from a 88
by chance would a ecu from a 88 work.. im thinking not since ser 3 ends in 87 doesnt?
  #129
Old 10-07-2012, 09:19 PM
Doug's Avatar
Received 10,871 Likes on 7,150 Posts
Yeah, not related to lack of injector pulse.
Upstream, at the primary side of the system, a faulty module might relate to lack of injector pulse...as the ECU relies on a trigger pulse from the negative side of the coil. But, since we have spark, I think we can safely eliminate the module
  #130
Old 10-07-2012, 09:22 PM
Doug's Avatar
Right. Ser III XJ6 ended in April 1987 as a 1987 model. The V12 versions carried on until 1992 but that's neither here nor there
A 1988 ECU will not work.
Contact David Boger at EverydayXJ. Great source for used Ser III parts.
  #131
Old 10-08-2012, 05:48 AM
Jose's Avatar
I still think something may be either disconnected, or incorrectly re-connected.
  #132
Old 10-08-2012, 09:04 AM
tudstuen's Avatar
Default Ecu?
After all we have investigated is it the ECU..? again there is power to the ecu at brown/slate wire.
  #133
Old 10-08-2012, 09:12 AM
Jose's Avatar
I refuse to conclude it is the ECU, but I'm not there to use my incredible Trial-n-Error Nician skills.
  #134
Old 10-08-2012, 10:43 AM
Doug's Avatar
I've about run out of ideas.
I'm ready to say "ECU" or "Injector Resistor pack". Both have low failure history, though, so it pains me a bit to suggest either. Not sure how to DIY bench test the resistor pack and I don't think there is any way at all to DIY test the ECU...except by substitution.
On the bright side neither should be very expensive used so, as guesses go, it won't be too painful.
  #135
Old 10-08-2012, 04:08 PM
tudstuen's Avatar
Default ok thanks
im going to see if Frank has and can send the resister pack. theres a few desent ecu's on enbay as well for not alot$$
  #136
Old 10-08-2012, 07:41 PM
denraden1's Avatar
Tudstuen: I have the Injector resistor pack, ECU and diode pac for a 1984 XJ6. AFAIK they are all in good working condition.
  #137
Old 10-08-2012, 08:22 PM
tudstuen's Avatar
Default ill take them all
i emailed you back when is a good time to call
  #138
Old 10-14-2012, 04:12 PM
tudstuen's Avatar
Default seats
will seats from a 96 xj6 bolt up to the 86?
  #139
Old 10-14-2012, 05:05 PM
Jose's Avatar
I've never tried it, but did you get the engine started?
  #140
Old 10-14-2012, 07:07 PM
tudstuen's Avatar
Default start
havent got the parts yet was suppose to get them yesterday but the guy couldnt meet me.. hopefully tomorrow..ill post what happens
Quick Reply: newbe help
