Newbie engine questions (SIII)
I've done work on most systems but have never adjusted internal engine components. That is likely to change as I want to do a tappet adjustment on my '87 XJ6. I found a video walking through the process, so feel comfortable enough with measuring the gap and the shims, but have a few basic questions first:
1) Which way does the engine turn? If I stand at the front of the car, and look towards the rear of the car, I think it will be clockwise. Is that correct?
2) The crankshaft pulley is the big one at the bottom, directly underneath the fan and (I think) water pump, correct?
3) Can someone tell me the socket size on the crankshaft? I'm guessing the best way to get to it is a big socket on a breaker bar, coming from underneath the car.
Thank you in advance! I'm a bit embarrassed to ask these Qs; I'm almost completely self-taught on old Cadillacs, and still have gaps in my knowledge.
The following 6 users liked this post by David84XJ6:
benji808 (07-16-2023),
Bill Mac (07-16-2023),
Jag7651 (07-17-2023),
Ken Cantor (07-17-2023),
Mkii250 (07-17-2023),
and 1 others liked this post.
With 1/2" square steed tube, you get relatively good clamping friction... most times I have had the spark plugs out, and haven't had it spin. Occasionally checking timing, have left plugs in and it was ok. Would not work trying to free a frozen engine, you would have to go underneath with the breaker bar for that. I suppose a little JB Weld would help.
Rgds
David
Rgds
David
benji808 (07-19-2023)
Can you post the link to this Video? I'd love to see it. I have a slightly noticeable "tick, tick" on the intake side which is likely either the tappets or noisy injectors. I think it is the latter, but it would be worth seeing the tappet adjustment done.
To all who may want to answer ( I have a stakedown kit and just did the valve covers so it isn't the tappet cups rising up).
I made the tool, and still having trouble getting it onto the bolt. I can get down there from the driver's side (opposite PS pump), but having difficulty locking it onto the nut Are you removing the fan or PS belt for extra clearance? I’ll keep at it…
If you are doing it with the plugs out try turning it via the ac compressor or alternator pulley etc. nuts. i.e. via the belt.
benji808 (07-20-2023)
Thanks to all for the ideas. This has been rather frustrating, as none of the suggested methods have worked so far. Was not expecting turning the engine to be the most difficult part of the job :P
Underneath I have the sway bar and a big pipe in the way...even navigating those getting up past the fan shroud does not offer much clearance.
Have spent several hours with David's tool...seems like there are some precise clearances that must be planned or lucked into - it's gotten close, but I have maybe 1/2" where it get hung up on the fan shroud and won't grab the bolt...might try a bigger exhaust clamp to choke up on the socket, or possibly cutting the bottom of the shroud...not sure at this point.
Plugs are out, belts are not turning it.
I'm considering just jumping the starter and hoping to get lucky...but that seems a bit imprecise for this.
Hopefully something works soon...way more time than I was hoping to spend on this crankshaft bolt.
David84XJ6 (07-21-2023)
