? newly installed re-built starter motor activates when battery is reconnected
hi: i just installed a rebuilt starter lucas starter. when i connected the positive battery cable the starter motor engaged without any turning of the ignition key. in fact the key isn't even in the ignition. can't figure out what i did wrong. there was only a cable that i held secure with a lock washer and a nut to one of the two posts and a red/white wire with a female connector that i plugged into one of two male prongs mounted on the starter. hmmm?????
The following 2 users liked this post by Doug:
Greg in France (10-15-2021),
JagCad (10-15-2021)
