No compression in cylinders 1 and 3
A few years ago I was given an 85 XJ6 which would not start (or even crank initially). Using the guides from these forums I managed to iron out quite a few small problems with the car and have since brought it back to life.
It now runs, but only just. Since it runs rough, I tested the compression and found that cylinders 2, 4, 5 and 6 all made 150 psi which seems quite good for its age and the odometer reading (200,000 km). However, cylinders 1 and 3 made absolutely no pressure at all.
What is most likely causing this? Exhaust valves? When I find some more time I will have a go at removing the head and have a look.
Pressurize the cylinder with compressed air using your own medley of fittings or a leakdown tester. See if it will maintain 15 to 35 psi (1 to 3 bar). Then listen to the hisssss....if the air is escaping through the dipstick tube or oil fill then you have a scuffed cylinder wall, cracked piston or worn rings. If the air escapes through the exhaust then you have a faulty exhaust valve or very worn guide. If the air is coming out the intake manifold you have a issue with your intake valve. If the air is coming out of the radiator cap you may have a cracked cylinder or bad head gasket. Remove the valve covers so you can observe TDC for the cylinder in question. For cyl 1 this is not necessary as you can use the timing marks on the balancer but for #3 it will be difficult to divine TDC any other way.
If it has been sitting for a long time prior to getting it running, you quite possibly have stuck/seized piston rings.
On those two cylinder, rotate the motor so they are down the bottom of their stroke and fill with ATF fluid, or a penetrating fluid to help loosen up any possible rust/carbon deposits that are holding the rings stuck to the pistons, let the fluid soak overnight.
