No kick down happening
After my series 1 come back from engine and gearbox rebuild, there were no wires on the gear box, or the kick down switch. I am happy to make up a new loom but can you please tell me where all three wires go. So far I have got:
Red/Black
Green
Purple/Brown.
I have three terminals on the kickdown switch and there have been three wires mentioned but only two destinations. Any advice would be greatly appreciated.
Red/Black
Green
Purple/Brown.
John, welcome to the forum. You will find this is a great place to learn things about your XJ. It was great to meet you at the British Day over the weekend. I just chased my wiring for the kick-down switch. The green wire comes from the bottom terminal on the horn relay which is located below the coil. This green wire is the +ve feed and connects to the bottom terminal. The red/black goes from the top to the terminal on the right side of the transmission. I only have two terminals on the switch. I suspect one of the terminals will be common with one of the others on the switch and is a take off feed for elsewhere. It may not be needed. Check which one is common with a test meter.
Also check my thread re my problems on departure from the British Day.
Re your front suspension alignment, I have some more info on that. I can p.m.. or it may be better to post a separate thread as there are many on here with much more knowledge than I.
John
John
John-Henry Te Hira (12-02-2019)
Received 3,939 Likes
