Noisy ventilation flaps, near rear screen...
Looking inside the boot/trunk, just below the rear screen and adjacent to the upper water channel, is a series of ventilation slots with loose movable flaps. Each time I close a door on the car, the escaping air pressure causes one or more of the flaps to rattle - a light metallic sound. No big deal I guess, but it is annoying!
At first I thought it was a loose exhaust hanger, but I traced it to this.
Is this common, or does anyone know of a fix? Access to the flaps is restricted through holes in the upper panel. Clearly they serve a purpose but I'd like to silence them, obviously without preventing the flaps from opening altogether.
Cheers,
Cheers,
Tony, this is not only common, this is one of the ways you know it's an Xj6. They're affectionately called Cow Bells.
They function, I'm told, as a one way air valve of sorts for ventilation of the cabin.
You can access them (there are 2) by removing the rear seat back. From that position you can either block them open, thereby doing away with the tinkling sound, or maybe even rip them out, which may be harder as they're set in metal tubes.
I find it sort of charming; like the car greets me whenever I get in and says Good-bye when I leave. But to each his own.
Thank you Elinor, somehow I suspected it would be another XJ6 eccentricity! I love your wonderfully positive slant on these little things, I have Cow Bells!! You've almost convinced me to leave well alone - that's difficult for someone who gets too **** about stuff (according to Mrs Jagent).
LnrB (08-22-2015)
I *just* fixed the cowbells on my Series III today.
After removing the insulation panel (if fitted) the air extractor pan is unbolted from the rear parcel shelf (access via the trunk/boot) and allowed to drop down....after levering it a bit to break the gooey sealant stuff.
(Or it can be removed entirely if you want....but that means shifting shifting the sunroof motor out of the way.)
With the pan dropped for access you can glue strips of foam (or felt pads, or....use you imagination) to the four little flaps.
Voilá....no more clanging flaps
I'm sure it's a British thing; who else on the planet would include or even conceive such a forward-thinking mechanical greeting system.
You have to admit, it beats the pseudo-sensuous female voice that says, "Your door is ajar." (Really!! And here was me thinking all this time it was a mere door!) Or the impersonal *thud* when one closes the door on entry or exit.
I'm more than a little **** about stuff working correctly, or at least having some function I can use, but there are some of these Eccentricities, Definitely British, that simply make the car what it is; the Quintessential Jaguar -- for me at least.
On the other hand, I don't think I could accept a substitute for the sensuous female voice in my SatNav (I know, pathetic isn't it? it's a guy thing....)
LnrB (08-22-2015)
The pan itself is #6 in the illustration....just so you have an idea. The actual noisemakers are #7. The gooey seal is #5
Air Extractor and Rear Parcel Shelf - Parts For Series III Saloon | Jaguar Heritage Parts UK
However, the person from whom we bought her wisely had her painted this Elegant Velvety Black (My Favorite!) as part of the Restomod/Conversion that took place in 1986 when she was but 10. He told us her dress consists of no fewer than 3 coats of black and 6 layers of clear coat. Perhaps the sky is reflecting off all those shiny surfaces in the sig picture making her look dark blue.
There are 10 more pictures of her in my Nix album if you're interested, it's here: Jaguar Forums - Jaguar Enthusiasts Forum - View Profile: LnrB
jagent (08-23-2015)
No worries, Tony, she was born (yuck) yellow, the correct name for which I'm told, was Buttercup, or maybe Primrose, no matter to me. I don't know if they were sold in black or not.
LnrB (08-23-2015)
The cows and their bells are gone!
Cheers,
those are Ventilation flaps that came from the factory with headliner fabric glued to the thin metal flaps, which are rivetted to the large black drain panel and hang freely.
but the foam backing dries out, dissolves, and the fabric falls off causing the metal-to-metal noise.
in the US, Joann's Fabrics, (and other Craft supply stores like Michael's), sell sheets of self sticking Felt material, which comes in different colors. (please do not use Pink like Doug did yesterday).
cut pieces of the Felt material the same size as the metal flaps and stick them to the flaps after cleaning any old material from the metal flaps with paint thinner so the Felt will adhere good.
Notice that there are two more similar free-hanging flaps behind the rear seat panel "firewall" or "bulkhead", and the same treatment applies.
lowering that metal drain panel is not easy, it is a pain, yes the Sunroof motor is in the way but you can lower the front edge enough to clean the drain panel and work the flaps.
Aus V8S
11-13-2015 11:01 AM
Richard_gib
09-12-2015 07:08 PM
