Not start series 2
Not start series 2
Hi, i am new owner of xj6 series 2 1978. I buy this car a month ago and its start and running but it make backfire. I decided to make a compession test (dry and wet), i remove all the spurks and the wires. I didnt disconnect the fuel pumb during the test. When i finish the test i put back the wires with wrong firing order and the car didnt start. Then next day i put the wire correct and change the spurks but stil dont start and there is also fuel leak from ezhaust and at AED pipe when i try to start.
Does i made damage?
What i can do to solve the problem?
Does i made damage?
Welcome to the Forums.
Please do an Intro in the New Members Area when time permits.
You have seriously flooded the beast.
Number the spark plug leads, REMEMBER #1 is at the REAR of that engine.
Remove the spark plugs.
Allow it to dry out, maybe a day or 2, depending on the weather wherever it is you call home.
Then refit the sparkers, and the leads, and see what happens.
These a basic simple engines, but flooding them is simply a time consuming thing to cure. It takes as long as it takes.
Down here we call that time "Beer O'Clock".
Grant Francis (02-10-2022)
Braydon Deffinger
09-05-2020 11:31 AM
