o2 light still on!?
I just changed the oxygen sensor on my series III yet the light remains on. I disconnected the negative battery terminal for over 30 minutes, and I drove a good 12 miles on the new sensor. the light is still on. What can I do, what could be wrong?
This morning right before I changed the o2 sensor I finished completely gutting and re-installing my catalytic converter, so it is essentially a straight pipe now. The o2 light was on well before I ever messed with the cat, so I don't know if that's pertinent.
Is there a second downstream o2 sensor I missed? Maybe a computer issue? Bad wire?
Your help as always is very appreciated.
AFAIK this oxygen sensor light is a "idiot light", ie it's not connected to the O2 sensor in any way. It was fitted to the US cars because the original o2 sensor lifetime was less than a certain amount (service interval?) so the light was installed to tell owners to go get the o2 sensor changed.
The light is driven from a counter. The counter is in the boot/trunk behind the rear panel. The rear panel is held in place by 2 of those big plastic screw things that release when you turn them half a turn.
The counter will look like a little black box. There is a button on it. I think you press and hold the button to reset the light. Not sure if you need ignition on or not. Fiddle and see
stellar-warior (05-19-2013)
well that was like the easiest fix EVER! and the answer is NO, you do not need ignition. I just popped the panel pressed the button down all the way with the tip of a pen and that was that. when I started the car... NO oxygen sensor light. haha wished I had done that months ago! anyways, thanks again. =)
rsa760041
23
09-25-2015 01:33 PM
