Oil cooler hoses
As far as flow matters, it won't matter which direction it goes thru the cooler. I believe you will find that if you are using original equipment, One way, They will just drop in easily and looks smooth. The other way, they look tangled. Lubricate the "O" rings liberally during install.
Thank you.
Larry Louton
Thank you.
Larry Louton
