oil gauge reading off scale
Hi replacing the oil gauge in my series 2 as the one there was from a 420 and it didnt really work.
Got a good second hand (i believe) got it plugged in and turn the ignition on and the gauge just slowly runs to max plus to the right.
Start the engine no change.
Looks like the wiring is connected right, at sender and the gauge, and the oil pressure warning switch , gauge has two green connected to one side, and white brown to the other. It did have a black earth connected to the bracket at the back not sure what thats for ! .
Any ideas folks?
Any ideas folks?
Only thing that springs to mind is that if the original gauge unit was not correct , then it may have an oil pressure sender that was also not correct to match. You may just have a mismatch.
When you pull the wire of the sender does the gauge go back to zero? just to rule out a wiring fault, as its behaving like the sender lead is earthed.
Sounds like its acting more like an oil pressure switch than a sensor that drives a guage. If it was switching an oil pressure light this is what you would expect , low resistance with engine not running and ignition on, so your oil light comes on. Then high resistance/open circuit with the engine running so the light goes out.
If you have a multi meter you could check what the sensor is doing in both cases.
yachtmanbuttson (04-15-2023)
I'm guessing you have a series 1 xj6 buy your car list?.....the wiring should be from sender> Black/ brown stripe to oil press/warning light...oil press/send White/brown trace to gauge, green powers the dash all instruments...if you have a different setup let me know what you have & i'll post the info or message me, i'm in Sydney
mickvic (05-15-2023)
https://www.jaguarforums.com/forum/m...2/#post2576146
Comment 11 of the link above and the attached 'Gentleman's guides' explain how the gauge and sender work and how to test and calibrate them. It does sound as if your sender is actually a switch for a warning light.
