Optical electronic ignition for S2 XJ12 ?
Hi Guys,
I put an electronic ignition replacement on my old white XJ12 about 10 years ago (now sold) and I want to put the same system on the red XJ12 but I can't remember who makes it.
It does away with the vacuum advance and magnetic sensor in the distributor (uses an optical system).
Can anyone remember who makes these?
Thanks,
Wilson Logan.
Thanks,
Wilson Logan.
Could it be the Re-Opus system?
https://www.martinrobey.com/part/24401 That's for EFI, there is another version for carbs.
"talking with the old Crane R&D guy, both XR700 and XR3000 are not recommended for V12, only up to V8s, but because of the internal circuits, the XR700 works great.
i tried a XR3000 and it ran terrible, changed back and all is oK ."
Hmmm... so I can run it in a V12 but I'm guessing that if the V12 is NOT a recommended implementation then there will be no optical pickup unit suitable for the V12 distributor and there will be no slotted interrupter wheel.
