Overheating fuel pump 86 XJ6
You may consider this a continuation of the thread Thick Black Smoky Exhaust then back to normal.
I installed a new Bosch fuel pressure regulator and Bosch fuel pump (69414), which cured the engine stumble but now the new fuel pump is running noisily and very hot some of the time. By hot I mean I'm afraid it will melt plastic things around it, or maybe start a fire on a long run.
I think my only remaining fuel delivery problem is the non-functioning cold start injector. Have any of you seen this overheating fuel pump issue before?
My car has the single inline pump located in the trunk. Thanks for any ideas!
Mkii250 (07-13-2014)
Noisy fuel injection pumps are either going bad or being starved for fuel. IF the pump is good another source of noise is cavitation. The fact that the pump is hot seems to suggest that it's not moving enough fuel to cool it. I'd look for a restriction on the suction side of the pump.
Charlene n John
09-28-2015 06:01 AM
deanh
09-06-2015 08:20 PM
