P1621 fault code - but my car has been off the road for 2 months! Please help.
Old 03-12-2008, 08:36 PM
Default RE: P1621 fault code - but my car has been off the road for 2 months! Please help.
had several problems .. found fuel pump faulty.. ecm relay.. crank sensor..ecu
Old 03-13-2008, 01:06 PM
Keith's Avatar
Hey, didn't realize this was going to be a trick question! Geeez, how unfair is that, 3 problems, I have enough problem dealing with one!
Old 03-13-2008, 03:11 PM
i meant on several different cars..not all at once lol
Old 03-13-2008, 08:31 PM
Keith's Avatar
OK, I'd hate to think anyone would be that unlucky!
Old 03-13-2008, 09:10 PM
Hey Pam
Have you or your tech checked front crank signal when fault occurs?
Getting to be a pretty know problem with these cars as they are getting older as car warms up sensors can and do fail OC or below spec output to ECM
Ive had a few including my own 95 xj6 last year
took me awhile to figure it out and i am a Jag Tech lol
Also P1621 ECM fault/failure is quit often caused by the ignition coils as they age and crack they begin to arc to the cam cover spark plug holes
and in turn the ECM can be damaged from the spiking or grounding out of the coils
The price of new ECM if you can get at our dealer is close to 3 grand
Its kind of hit or miss on getting a good known ECM
Good luck and continue to keep us posted
Old 12-30-2014, 07:45 PM
Induzido's Avatar
Default Sovereign 3.2. Fault code p1621
Hi guys
My Jag have problems again.
Yesterday i put my Jag into my garage, everything ok. Today when i go to The work, The car won't START, The engine don'run. The alarme don't Work, when i Put The key in The ignition switch, all dash is on, but when i START The engine .... Nothing.
The shifts with The ignition on go to The rear, D, 2 and 3 without brake.
My diagnosis show The fault code P1621, i clean The fault , but appear again.
Someone could help me.
Regards
Isoruku
06-19-2020 12:54 PM
Nati
05-16-2020 08:30 AM
DrScientist
12-09-2015 07:36 PM
jdzubas
10-04-2015 09:14 AM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
Quick Reply: P1621 fault code - but my car has been off the road for 2 months! Please help.
