Pabst Blue Ribbon meets Tea and Crumpets
#82
Just ran across this thread. Up until post #6 I was as usual, thinking poor dude... But then the painted pics! Good friggin job Bro! The sbc will make it drive like it should have all along and you'll love it.
On the stub axles, I know you don't want to... but send them to Coventry West with $400 and you get back really nice ones all set up with new bearings and ready to bolt in with no noise and no leaks.
LnrB (11-11-2016)
#83
So the rear diff, axles, hubs and carriers are out at a transmission shop getting a full service. New bearings for all the wheels, new hub carrier on one side, new u joints (MOOG 330 for the half shafts if anyone needs that info) new sub axles oil seals, and a general clean up.
They’re also going to try and see if dana 4.27 gears fit in the housing, Ive heard it just needs new bolts but theyre going to test it out while its apart.
#84
#88
Even Nascar and Formula1 use rubber and silicone flexible hoses.
http://st.hotrod.com/uploads/sites/2...ar_engine-.jpg
https://goo.gl/images/sWi9WO
From one lumper to another... you should rethink the hose and put back the OE brake booster and pedal assembly. This is the type of engeneering that gives lumps a bad rap.
#89
Its going to be running high hp numbers (i have edelbrock heads, holley efi, lunati cam and single borg warner 76mm turbo in the process of getting ordered), and the crade is only rubber mounted in the front not the rear two mounts are solid. and the stock brake booster and master are not in any shape to go back in. Im putting in a 74 corvette manual master cylinder.
Im doing this build the way i want it, so if i set it up and hate it then i can change it. Im in no rush to get it perfect id rather make mistakes for myself and learn in the process
icsamerica (01-05-2017)
#90
Received 2,399 Likes
Sun:
Go for it wrong or right!!! Your car. I don't agree as to the need for a solid engine trans mount. Might even be counter productive. But, do as you please.
As to the almost solid top "hose"! Apologies, it isn't that pretty!! My view only. The only one that counts is yours. Again, apologies, but that welds is kinda "dirty". Is it sound????
But, kudos on effort....
Carl
Carl
#91
Good job on those wheel wells! I never realized I didn't care so much for the original design until I saw Fi-Boys XJC a few years back. This is a killer build too... I'm sure you've prob seen it.
FiBoy's XJ12C restoration; rebuilding a Jaguar XJ V12 Coupe
#92
Did some more work on the jag, added a switch panel (no push start i want to use the stock key start) added power steering, mounted the manual master cylinder, little to no flex on it when i push down on it, and mocked up a temporary exhaust just so i can avoid any more complaints from the neighbours
#94
Check out speedway part number 91013822
I used this kit for my setup with good results.
Universal Mild Steel Dual Exhaust Mandrel Bend Kit, 2-1/4 Inch
or 2.5 inch same price.
Universal Mild Steel Dual Exhaust Mandrel Bend Kit, 2-1/2 Inch
I dont know how they do it!
#95
#98
The following 2 users liked this post by sunchip:
Doug (03-20-2017),
Flint Ironstag (03-28-2017)
#99
#100
