pag oil capacity for a sIII
The question you are asking is hard to answer. How do you know how much oil is still left in the system? You can leave the new compressor out of the equation by blanking of the ports to it and evacuate the system by itself. But some residual oil will remain. Replacing the condenser / receiver dryer bottle will eliminate a lot of any residual oil. At this point if your new compressor has 3 ounces, Add 5 to 7 ounces and You should be safe from overfilling.
Thank you.
Larry Louton
Thank you.
Larry Louton
