Part Number EAC4371
Received 10,988 Likes
Pretty sure that that's the early version of the full load enrichment switch, which fattens the fuel mixture when manifold vacuum drops below xxx-value (about 3 inHg as I recall). it was replaced at some point with the more commonly know "blue white switch".
The engine will run fine without it...to a point, at least....but I would not recommend eliminating it. It protects the engine under heavy load
The following 3 users liked this post by Doug:
The following 3 users liked this post by Grant Francis:
OK, Ive got another question, the above drawing shows the switch connected from the manifold via a 4 way connector with hoses going to the heater, the switch, the manifold and the distributor. My car has a dedicated hose for the distributor and at this stage the heater and a/c is not working and does not need to be connected. So can this switch be connected via the manifold only with no other hoses?
Con
Con
I am assuming the 1/2 size engine here, not the V12??? Nothing in your profile telloing us the beast at play here.
Yes, on the V12 it is usually attached to an open vac spigot on the rear of the A Bank Inlet.
You need constant vac, as in NOT via any thermo switches etc etc. The vac holds the contacts OPEN, and this is the key.
BUT
That vac line needs to dump vac quickly as needed, so connected to other circuits that "may" run a vac reserve tank will not be good.
BUT
This is the wide open throttle switch
It is a vacuum-operated switch which is “normally closed” i.e. at atmospheric pressure it is closed. At low throttle, there is high vacuum pressure and so the switch is held open. At full throttle the vacuum drops to nearly nil and so the switch closes, which instructs the ECU to enrich the fuelling. The switch is set to switch states from closed to open at 4mm Hg vacuum
on USA market cars this was not used, but instead a rotary switch to sense throttle position was employed which also has a closed throttle sensor in place of the microswitch on other market cars.
This vacuum operated switch is obsolete but can be replaced by a Honeywell vacuum switch part number 76061
I tolerate the lesser cousins now with the S and the X, and YES, I measured, the real engine will NOT fit.
ALL in jest of course, I am too old to take offence, and as I have said too many times, "If you own a V12 you MUST have a warped sense of humour".
BUT, we are going off topic, and that is not good.
Grant Francis (05-17-2020)
