PDWA replacement
PDWA replacement
1980 XJ6 4.3L US model.
My PWDA is rooted!
I have found similar looking ones for Triumphs, and XKE's
Does anyone know if there is an acceptable replacement?
I am not worried about the light working. I just want the connections to fit, and it not to leak.
I Checked with Barrett and they suggested to ask you guys.
Bobmo
Merry Christmas
My PWDA is rooted!
Bobmo
Merry Christmas
Received 10,989 Likes
Pressure Differential Warning Assembly. Or something like that.
The brake fluid goes into the cylinder. If there's a leak in the system, the pressure differential moves a shuttle valve which in turn contacts the switch, closing the circuit, and causing the'brake' warning lamp on the dash to glow.
It can be seen roughly in the center of this illustration:
Series III cars had'em until '83 or so.
Sometime they can be opened up and cleaned, and new seals/o-rings installed, to return to good operating condition. I've never researched a substitute but wouldn't be surprised if MG, Triumph, Rover, etc used the same part
This video, although for a Mercury Cougar, will give you a feel for how it's done. Skip to 15:07 to see the shuttle valve/piston. Not sure if any repair parts are available for the PDWA used on Brit cars
Jag7651 (12-17-2020)
Land Rover Defenders use the same part (AAU1700) for the switch. As for the whole assembly, I'm not sure.
https://rovahfarm.com/seriesbrakespage2.htm
The following 2 users liked this post by bobmo:
littlelic69 (12-17-2020),
Mkii250 (12-19-2020)
You might try Moss Motors, they have two of them listed: here. I used to buy from Moss back when I was in college in the 60's and I had a $250 MGA. I like there web site because you can search for a part across all British car brands at the same time. This week I needed a temperature guage sending unit for one of my series IIIs and it turns out that sensor was used in MGs, Triumphs, etc for years. Plus their price was much less than the Jaguar parts suppliers. They bought out XJs Unlimited in San Luis Obispo last year and they now ship Jaguar parts from both California and their facility in Virginia. Plus they will send you a free paper parts catalog and they send out a quarterly magazine. I highly recommend them.
Jeff
Jeff
Thanks Leon.
So I solved my leaking problem.
My sending unit had been smashed and all that was left was the bronze bit that looked like a shraeder valve sticking up.
My leak was, I thought, around the seal and I did everything to stop the leak. Finally my son stopped in for a visit and had him pump the brakes while I watched what happened.
It appears that fluid was leaking through the sending unit.
I pulled it out and soldered both sides shut and the leak is no more.
I also tried to fix the orings but never could find the correct size.
Most of the oring kits dont match up well for necessary id/od. and since its just there to alert the signal switch, which is now permanently non functional, I've reduced the PDWA to an empty manifold.
Simplify!
Bobmo
Simplify!
Bobmo
