Pertronix Coil & Distributor Xj6 1984 SIII
#41
Hi Greg,
1* I think it’s more of a question of efficiency in conjunction with a"better spark". yes they claim to have a better spark but i feel i really noticed the difference when i changed of over from the lucus distributorto the petronix unit.
2* I am not a 100% on this but leads do vary in quality and vary inresistance which is important ... i could be wrong "insert intelligent response here"
3*in regards to higher octane gas use it with or without the petronix the higher octane fuel has a higher stability under compression and a more complete burn and can be compressed to a higher degree without combusting in the absence of an ignition source
i have run my xj6 on 98octane since its rebuild and have never looked back
4*In my instance i had a lumpy idle and was a bit all over the place , wheni changed over it had resolved my issue
Mkii250 (06-19-2014)
#42
#43
Agreed. I added a Pertronix distributor replacement on my list of things to do for the last weekend this month, assuming amazon gets it here in time. I hope I don't run into too much troubles swapping it. Never had the distributor out on this car before. Chevys, many, many times. My Jag, no as of yet.
Dale
Dale
#44
Received 10,874 Likes
Dale
Dale
If you've done it on a Chevy, you can do it on a Jag !
#45
Thanks for the vote of confidence, Doug! I think I'll be able to handle it.
Couple of quick questions. Will my "very basic" inductive timing light that I have work for setting the timing? Or do I need to shop for an upgrade?
Also. Can I remove the ballast resistor that is on top of the coil? I seem to remember reading that it wasn't necessary.
Dale
Dale
#46
#48
Received 2,399 Likes
Two points from old guy:
No criticism as to the Pertronix system. A definite improvement in tech over an old point and condensor sytem.
But, replacing a 30 or more year old Lucas with any decent newer distributor is likely to show a difference.
So, a fair comparison might be replacing the well worn Lucas with a NOS unit, if that were possible.
Or, a rebuild of the Lucas. Shaft bushings, amplifer, wires, ignitor, cap and leads!!
Rather than leave the amp in place merely to cap the holes, remove t and install bolts to do that. Put the amp away for a rainy day. If I isn't already cooked, eventually it ill
And tidies the bay.
Just musing !
Carl
And tidies the bay.
Just musing !
Carl
#49
Hi ,
I certainly tried a rebuild of the lucus dizzy as the first choice with new leads and coil pack and in all fairness I wasn't satisfied with the end result, I certainly want to keep the old cat as original as possible hence every part I change I keep in the shed protected
But moving to the new tech certainly put a little more growl into the ***** cat
#50
Pertronix: I am intrigued by the accounts of a less lumpy and closer to normal idle speed.
#51
scooternva
20
09-27-2023 11:25 AM
