Pertronix Ignition System. SIII 1985
Received 10,871 Likes
Received 2,399 Likes
Ian:
Why? If your car is a Series three and has electronic ignition ? It is a good system. and performs well if not just plumb wore out!
If so, not a bad choice. Most curves are a compromise. And the older ones less fitting to conditions Fuel is far different than the 80's.
So, can you find the curve for the present unit.. Degrees of advance from Idle til all advance in?
Then, as I've read, the petroix tech folks are helpful ad can opine if their unit is close. I expect they might claim their's is a better curve...
Carl
Carl
Mkii250 (04-08-2020)
Several Forum members have used this distributor on EFI XJ6s, but it is not recommended by Pertronix (their literature states for carburetor models of XJ6 only). It has less performance than the OEM ignition system. The high performance Pertronix Distributor D171618 and 45001 ignition coil (45k volts & .6 ohm) has better performance, and have been reported as working well by forum members on their XJ6s; but, if you are in California or New York, it is not approved for pollution controlled vehicles.
The question: is your interest in a new ignition system a desire for better performance, better idle or is your distributor on it's last legs. If you pull the cap off your distributor and with a paper towel grab the rotor and wiggle it from side to side... and the upper bearing is failing, then you may want to explore the D171618 distributor (with Vac advance) and matching coil. (you do not need the ignition amplifier with this distributor...be sure to plug the two mounting holes in the intake manifold if you remove the amplifier). The alternative is to send distributor to overhaul specialist.
If your distributor is ok and your are just looking for better idle or performance, Pertronix has a replacement ignition module (inside the amplifier) that out-performs the OEM Delco unit and will support the .6 ohm coil. This module is direct replacement and in approved for EFI XJ6s in California and New York.
( I am using this Pertronix ignition module and the 45K volt coil on my EFI XJ6 and you can tell the difference in smoothness at idle... I overhauled my OEM distributor)
Since we are finding ourselves with extra time on our hands, here is a long thread with some of the details for you to consider. Jaguar XJ6 S3 Ignition System Repairs:
Rgds
David
Ian,
Several Forum members have used this distributor on EFI XJ6s, but it is not recommended by Pertronix (their literature states for carburetor models of XJ6 only). It has less performance than the OEM ignition system. The high performance Pertronix Distributor D171618 and 45001 ignition coil (45k volts & .6 ohm) has better performance, and have been reported as working well by forum members on their XJ6s; but, if you are in California or New York, it is not approved for pollution controlled vehicles....................
and should note that Pertronix advised me that "The Ignitor II module along with new coil has a bigger output than the OEM equipment", though they wouldn't guarantee the D171618 would work on the Series 3. It works nicely on mine.
That's good info. I'm running the D171618 https://www.jaguarforums.com/forum/x...stomer-203294/
Rgds
David
Doug (03-30-2020)
I'm using Pertronix 0.6 ohm 45011 with my D171618. Here are the installation instructions that came with the distributor. Please note the pages are out of order but they are all there.
1.5 or .6 Ohm coil will work.. The .6 Ohm coil will allow you to open-up the plug gap over-book by .005
"Web-site: PerTronix D171618 Flame-Thrower Electronic Distributor Cast British 6 cyl Plug and Play with Ignitor
ADDITIONAL INFORMATION:
Performance Distributors for British Engines Flame-Thrower HP distributors take the performance line of distributors one step higher. That's right, HP stands for High Performance, and that's what you get with our all new HP distributors. These distributors feature patented Ignitor II technology and are available with top exit or our new side exit caps. For optimal performance, use our Flame-Thrower II 45,000 volt coils. "
The electrical module in the D17600 will only match the 3.0 Ohm coil
Rgds
David
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/955x518/ignitioncoils_3__f500f0d84f7fd4283a43e901ec12a85c28563eb2.jpg)
Mkii250 (04-01-2020)
If the smog shop is legit, they will pick up on the Pertronix timing at 10 degrees, where the placard on the bonnet calls out 17 degrees for OEM distributor... I have watched them thru lobby to shop window hook up the timing light, spend a few minutes looking around, only to give up and check the box OK. I have three white marks, 0-17-33, they would not be able to see degree marks. If they asked me which mark was correct, then I would know they were checking. They really like the modern cars where they just plug into Computer.
David
David
anjum (04-02-2020)
David84XJ6 (04-08-2020)
DavidXJ6
Good point for CA folks. I wonder if merely setting the pretromix to 17 would effect running enough to flunk the Smog sniff test..
Way back, my preSMOG job on my IHC Scout II was to screw in the idle jets to the point that the car would just barely resist stall. back AKA in SMOG parlance "best lean idle"!. And, once done screw them back out to best idel!!! It's truck engine was far from a clean design. It ate gas!!
Jeep coming upfor SMOG, OMG!!!
Carl
Carl
DavidJC
08-16-2018 08:41 AM
