Petrol tank
Old 10-21-2015, 05:35 AM
adenshillito's Avatar
Default Petrol tank
to convert a series 3 tank (which has three exit points, 1 to engine, 1 to vapour filter, 1 to return pile) back to a series 2 or carburetor-type tank what sort of plugs, gaskets or whatever do I need to safely plug the vapour and return outlets on the tanks?
Old 10-21-2015, 06:39 AM
Wilfred88's Avatar
You cannot block the vapor outlet. Due to expansion your tank might pop without an expansion outlet.
Basically what you need to do is block the return and that's it.
Doesn't really matter how you do it. Just make sure it is watertight. You could just plug the hose with a bolt and clamp it with a hoseclamp .
Old 10-21-2015, 07:47 PM
Thanks~
didn't the earlier take lack a vapor escape outlet at the top? thought they just have the one-way out to the engine? how was gas pressure vented on the pre-EFI tanks?
cheers~
Hartford6
12-18-2015 06:14 AM
ratgawd
11-03-2015 05:21 AM
JaguarSV8
10-25-2015 01:47 PM
Cairn
10-21-2015 10:47 AM
JagsDaughter
10-18-2015 11:38 AM
Quick Reply: Petrol tank
