View Poll Results: What's a good color for a XJ6
Red
55.56%
White
33.33%
Blue
33.33%
Purple
11.11%
Multiple Choice Poll. Voters: 9. You may not vote on this poll
PLEASE help NOOB with 85 XJ6 issues
See if you can get one of these, (or a pdf equivalent).It's a Mine of Information.
https://www.ebay.co.uk/i/233102720786?chn=ps
Also have a read here:-
Fuel injection and the Jaguar XJ6 4.2 Series 3 / AJ6 Engineering
It takes you through the whole EFI system and what can go wrong. Unlike systems of today, the Lucas/Bosch L-Jetronic EFI system is analoge, so forget about digital and fuelling maps, they don't exist here !
The fuel pump is kept running via the fuel pump relay and this is supplied with volts, (except at starting), via two small contacts in the mass flow meter. Over the years these lose their springiness and can fail to make contact, so the car starts and when the ignition switch is returned from the "Start" position, the supply ceases and the engine stops. Other thing is to clear out the fuel tanks and clean the filter gauzes, plus replace the main fuel filter in the engine compartment.
The whole EFI system relies on pulses taken off the back of the coil. Without these the EFI will not fire the fuel injectors. As others have said, the Cold Start Injector eases a cold start, but is not totally essential you just have to crank the engine more.
Received 10,974 Likes
The following 2 users liked this post by Doug:
LnrB (02-07-2019),
yachtmanbuttson (02-07-2019)
cbryantjr85
10-21-2016 03:46 PM
richardjay
07-05-2015 04:50 AM
driftr319
07-29-2011 12:30 PM
swift707
12-17-2009 11:00 AM
