power antenna motor andor relay
Old 10-08-2015 | 07:55 PM
jim the chief's Avatar
Default power antenna motor andor relay
need power antenna delay relay wire diagram for my 1985 xj6. the relay is a lucas 33388a 1285 12 volt. its light green with 5 prongs on the bottom.the terminals are marked 1 2 3 4 5 . i would like to buy a replacement but cannot find a source or a diagram for this one. can anyone help with a source or know how to wire it. the motor is working and the antenna does move and i don't want to ruin this relay by wiring it wrong.i do get a 6 volt reading on one of the wires with a volt meter. please help. Thanks, Jim.
Old 10-08-2015 | 09:28 PM
Doug's Avatar
#1 Purple wire from fuse #3
#2 Black ground wire
#3 White/pink from radio
#4 Blue/white to motor
#5 Blue/red to motor
Old 10-09-2015 | 05:45 AM
yarpos's Avatar
If you want a wiring reference , the S57 wiring diagrams posted in the "How To" stickys at the top of this section are very good. Clearly segmented and laid out, also includes location of relays, earths, connectors, power distribution etc. A great aid if you are inclined to chase electrical gremlins yourself.
Old 10-09-2015 | 03:33 PM
Jose's Avatar
contact David at Everyday XJ for a good used replacement relay:
Everyday XJ
or contact SNG Barrat USA store for a new one:
SNG Barratt - The Ultimate Jaguar Parts Specialist
Old 10-09-2015 | 07:49 PM
thanks guys. with your help and advice i got the relay wired correctly and the antenna is working properly, the radio sounds good. i was stuck and you all bailed me out. thanks again
johndahlheimer
09-17-2020 03:10 PM
Bcrary3
09-26-2015 10:36 AM
cyber3d
09-15-2015 02:37 PM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 04:03 PM
Clamdigger
09-12-2015 03:43 PM
Quick Reply: power antenna motor andor relay
