Power window fuse / circut breaker?
Received 10,973 Likes
The window circuit has two breakers on the RH component panel, below the glove box. They're about 1" square and have red/slate wires.
With your test light it's obviously a simple matter to see if they're passing volatge...or simply swap the wires and see if the problem moves to the driver's side windows.
If you have a dead breaker it can be replaced with a more generic type or even a 30 amp fuse. Replacement breakers from Jaguar are stupid-expensive.
