Power Window Relay Location?
I'm trying to locate the power window relay on my '81 XJ6. My Haynes manual is somewhat less the useful since it gives no locations and the wiring diagram doesn't match what I'm seeing on the car. I have no power to any of the window switches or the sunroof switches. Any help is greatly appreciated.
Under dash, right side, next to fusebox. There are three black circuit breakers, two terminals on each. One is for door locks, one is for right side windows, the other is for left side windows and sunroof (ok, so maybe the sunroof is with the right side windows, it's been a long time). A shorted window switch will burn up the breaker, if failed they must be replaced. Good used ones in stock if you need them.
By the way, you did make sure the master switch above the window switches on the center console was good, right?
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
