Radiator/coolant light?
Received 10,936 Likes
The low coolant sensor is on the brown coolant tank....towards the front of the tank, about 1/3 up from the bottom. Make sure it's plugged in ! If not you may have to search for the dangling wire.
Sometimes the sensor itself gets dirty. It can be removed for cleaning . It presses into a rubber seal/grommet. Better order a new sealing grommet first, though.
The sensor works in conjunection with a transmitter under the dash. These almost never fail. I've never learned how the transmitter works. Might be interesting to open one up one day.
Benhamtroll (07-08-2011)
rsa760041
23
09-25-2015 01:33 PM
